[GRASS-dev] Fwd: Re: [OSGeo-Discuss] OSGeo4W maintenance activities
Rashad Kanavath mohammedrashadkm at gmail.com
Sun Feb 21 08:15:07 PST 2016
Hello Markus,
As this part related to GRASS, I am writing it here.
Moving to cmake is one thing. But I don't know if that is blocking msvc
build. Did anybody tried to build grass with msvc?
BTW, What  will be your opinion on adding an cmake build system?. It can
ofcourse co-exists with current auto-tools one.
On Sun, Feb 21, 2016 at 8:49 PM, Markus Neteler <neteler at osgeo.org> wrote:
> FYI
> (ongoing discussion in the other list)
> ---------- Forwarded message ----------
> From: "Jürgen E." <jef at norbit.de>
> Date: Feb 21, 2016 4:14 PM
> Subject: Re: [OSGeo-Discuss] OSGeo4W maintenance activities
> To: <discuss at lists.osgeo.org>
> Cc:
> Hi Markus,
> On Sun, 21. Feb 2016 at 15:47:00 +0100, Markus Neteler wrote:
> > since I'm not familiar with compilation on Windows, could you briefly
> > indicate what's needed / which efforts to compile GRASS GIS with MSVC
> rather
> > than mingw given the recent efforts on the 64bit packaging?  Just to
> better
> > understand...
> Not sure.  I'd probably start with moving the build system to CMake.  Like
> I
> already did for just the GRASS libraries at some point in the past (some
> code
> changes I submitted to make the libraries build with MSVC were also
> accepted
> back then).
> But moving all the modules there is probably a much bigger task and I'm
> also
> not sure about the acceptance of this. ;)
> It might also be possible to integrate msvc into configure/make (at least I
> think I've seen configures with MSVC stuff in them).  Although you'd still
> need
> a unix like shell, make and other tools from mingw/cygwin.  But I never
> explored that option (mainly just because the CMake approach went much
> better
> with what I needed for QGIS).
> But again GRASS works fine in OSGeo4W AFAICT (and as you know and that's
> still
> not much ;)) and hence I don't see the big problem of mixing MinGW and MSVC
> DLLs.  It doesn't add much to the mess of having different MSVC compilers
> and
> runtimes around.   IMHO that part of Rashad's issue is just a CMake bug
> and not
> a fundamental flaw in OSGeo4W.
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden
> http://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> Discuss mailing list
> Discuss at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/discuss
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160221/3c5e2588/attachment.html>
