[GRASS-dev] Fwd: Re: [OSGeo-Discuss] OSGeo4W maintenance activities
Radim Blazek radim.blazek at gmail.com
Wed Feb 24 01:18:53 PST 2016
On Sun, Feb 21, 2016 at 5:15 PM, Rashad Kanavath
<mohammedrashadkm at gmail.com> wrote:
> Hello Markus,
> As this part related to GRASS, I am writing it here.
> Moving to cmake is one thing. But I don't know if that is blocking msvc
> build. Did anybody tried to build grass with msvc?
Yes I did, the libs only.
I started with https://github.com/swig/cccl but that was failing
because cl.exe was givin deprecation warning.....
In the end, I managed to compile libs with command (manually changed Makefile):
cl "-nologo" "-LDd" -Zi "-Fe$@" $(C_SOURCES) $(ALL_CFLAGS) $(ALL_LIBS)
"-link" -DEBUG -OPT:NOREF -DEF:$(LIB_DEF)
"-LIBPATH:c:/users/radim/devel/grass-7.0.0-msvc/dist.i686-pc-mingw32/lib"
"-LIBPATH:/c/OSGeo4W/lib" "-LIBPATH:/c/OSGeo4W/apps/msys/lib"
"-LIBPATH:/c/users/radim/devel/grass-7.0.0-msvc/mswindows/osgeo4w/lib/"
"-LIBPATH:C:/lib/" "-LIBPATH:C:/Program Files (x86)/Microsoft Visual
Studio 10.0/VC/lib/" "-LIBPATH:C:/Program Files (x86)/Microsoft
SDKs/Windows/v7.0A/lib/"
+ some manual hacks like copy proj_i.lib c to proj.lib, comment
lgamma(), get dirent.h, replace .o by .obj in Grass.make and so on.
I think that adding support for MSVC to current GRASS build system is
possible, cl.exe is C compiler.
Radim
> BTW, What  will be your opinion on adding an cmake build system?. It can
> ofcourse co-exists with current auto-tools one.
> On Sun, Feb 21, 2016 at 8:49 PM, Markus Neteler <neteler at osgeo.org> wrote:
>> FYI
>> (ongoing discussion in the other list)
>> ---------- Forwarded message ----------
>> From: "Jürgen E." <jef at norbit.de>
>> Date: Feb 21, 2016 4:14 PM
>> Subject: Re: [OSGeo-Discuss] OSGeo4W maintenance activities
>> To: <discuss at lists.osgeo.org>
>> Cc:
>> Hi Markus,
>> On Sun, 21. Feb 2016 at 15:47:00 +0100, Markus Neteler wrote:
>> > since I'm not familiar with compilation on Windows, could you briefly
>> > indicate what's needed / which efforts to compile GRASS GIS with MSVC
>> > rather
>> > than mingw given the recent efforts on the 64bit packaging?  Just to
>> > better
>> > understand...
>> Not sure.  I'd probably start with moving the build system to CMake.  Like
>> I
>> already did for just the GRASS libraries at some point in the past (some
>> code
>> changes I submitted to make the libraries build with MSVC were also
>> accepted
>> back then).
>> But moving all the modules there is probably a much bigger task and I'm
>> also
>> not sure about the acceptance of this. ;)
>> It might also be possible to integrate msvc into configure/make (at least
>> I
>> think I've seen configures with MSVC stuff in them).  Although you'd still
>> need
>> a unix like shell, make and other tools from mingw/cygwin.  But I never
>> explored that option (mainly just because the CMake approach went much
>> better
>> with what I needed for QGIS).
>> But again GRASS works fine in OSGeo4W AFAICT (and as you know and that's
>> still
>> not much ;)) and hence I don't see the big problem of mixing MinGW and
>> MSVC
>> DLLs.  It doesn't add much to the mess of having different MSVC compilers
>> and
>> runtimes around.   IMHO that part of Rashad's issue is just a CMake bug
>> and not
>> a fundamental flaw in OSGeo4W.
>> Jürgen
>> Jürgen E. Fischer           norBIT GmbH             Tel.
>> +49-4931-918175-31
>> Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
>> +49-4931-918175-50
>> Software Engineer           D-26506 Norden
>> http://www.norbit.de
>> QGIS release manager (PSC)  Germany                    IRC: jef on
>> FreeNode
>> Discuss mailing list
>> Discuss at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/discuss
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Regards,
>    Rashad
