[GRASS-dev] [GRASS GIS] #2932: z values read instead of intensity in r.in.lidar
trac at osgeo.org
Tue Feb 23 14:29:23 PST 2016
Reporter: dnewcomb | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Default | Version: svn-trunk
Keywords: | CPU: x86-64
Platform: Linux |
The following command:
r.in.lidar -o -i -d --overwrite
input=/data1/lidar_test/LA_37_20960803_20150430.las
output=803_20ft_ground_intensity
base_raster=D05_37_20960803_20141231 at PERMANENT method=mean zrange=-10,0
class_filter=1,2,3,4,5,6,8,9,10,11,12,13,14,15,16,17,18
Gives me a grid with values with negative numbers. LiDAR intensities are
always positive, so the mean values should also be positive. Since I have
only included Z values less in elevation than the ground surface, I assume
the values are from the Z coordinates.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2932>
