[GRASS-dev] [GRASS GIS] #2931: r.neighbors shifts output raster by 360 degrees (WGS 84)
trac at osgeo.org
Thu Feb 25 08:06:06 PST 2016
Reporter: markinpt | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 6.4.6
Component: Default | Version: 6.4.3
Resolution: | Keywords:
CPU: x86-64 | Platform: MSWindows 8
Comment (by markinpt):
Sorry, I left out one key item. I am running r.neighbors through the QGIS
GUI.
Given that context, what do you mean by "Current Region"? The Grass region
extent? I left that as default because the source raster is the same
extent that I wanted as an output.
Also, I am not sure if the -a flag is used or not in QGIS. I assumed this
was a Grass issue but perhaps it is the way QGIS is calling r.neighbors?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2931#comment:2>
