[GRASS-dev] -s flag in temporal modules
Luca Delucchi
lucadeluge at gmail.com
Wed Feb 24 03:25:44 PST 2016
On 23 February 2016 at 17:59, Sören Gebbert
<soerengebbert at googlemail.com> wrote:
> Hi,
> I would like to suggest that we do not use a flag for suffix
> specification, but instead an option for this purpose. Like "suffix"?
I started with t.rast.accdetect, mostly working but
> The suffix option will specify which type should be created:
> * time with full format (time) 2001-01-01T00:00:00
this is not working, it is returning this problem
t.rast.accdetect input=precip_sum at climate_2000_2012 occurrence=B
start='2001-01-01' stop='2008-12-31' cycle='12 months' basename=b
range=1,10 suffix=time
12
Processing cycle 2001-01-01 00:00:00 - 2002-01-01 00:00:00
File "/home/lucadelu/compilati/grass_trunk/dist.x86_64-pc-linux-gnu/scripts/t.rast.accdetect",
line 589, in <module>
main()
line 317, in main
maximum_strds, dbif)
line 531, in compute_occurrence
occurrence_map_id = map.build_id(occurrence_map_name, mapset)
File "/home/lucadelu/compilati/grass_trunk/dist.x86_64-pc-linux-gnu/etc/python/grass/temporal/abstract_map_dataset.py",
line 174, in build_id
name, layer = name.split(":")
ValueError: too many values to unpack
maybe should be enouh to change time format using 2001-01-01T00.00.00
or something similar?
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
