[GRASS-dev] -s flag in temporal modules
Vaclav Petras
wenzeslaus at gmail.com
Wed Feb 24 06:23:44 PST 2016
On Wed, Feb 24, 2016 at 7:36 AM, Sören Gebbert <soerengebbert at googlemail.com
> wrote:
> Indeed, a colon ":" must be avoided in map names, since the layer of
> vector maps are identified this way (time stamped tables).
> I think your suggestion of using 2001-01-01T00.00.00 is a good solution.
Is it really necessary? Where exactly the colon is used? Is it internal?
Isn't ISO-compliant date-time format good enough reason to change it?
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160224/4483047f/attachment.html>
