[GRASS-dev] [GRASS GIS] #2942: Startup after Novice Install
trac at osgeo.org
Sun Feb 28 20:05:14 PST 2016
Reporter: pactriglo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Startup | Version: 7.0.3
Keywords: | CPU: OSX/Intel
Platform: MacOSX |
Last login: Sun Feb 28 19:57:43 on ttys000
BenjamiillosMBP:~ benjaminpezzillo$
'/Applications/GRASS-7.0.app/Contents/MacOS/grass.sh'; exit
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
Python 2.7.10 found.
Starting GRASS GIS...
dyld: Library not loaded: /usr/local/lib/libintl.8.dylib
Referenced from:
/Applications/GRASS-7.0.app/Contents/MacOS/lib/libgrass_gis.7.0.3.dylib
Reason: image not found
File
"/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/gis_set.py", line
31, in <module>
from core import globalvar
File
"/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/core/globalvar.py",
line 29, in <module>
from core.debug import Debug
File
"/Applications/GRASS-7.0.app/Contents/MacOS/gui/wxpython/core/debug.py",
line 66, in <module>
Debug = DebugMsg()
File
line 37, in __init__
self.SetLevel()
File
line 42, in SetLevel
self.debuglevel = int(grass.gisenv().get('WX_DEBUG', 0))
File
"/Applications/GRASS-7.0.app/Contents/MacOS/etc/python/grass/script/core.py",
line 934, in gisenv
s = read_command("g.gisenv", flags='n')
File
line 442, in read_command
process = pipe_command(*args, **kwargs)
File
line 417, in pipe_command
return start_command(*args, **kwargs)
File
line 355, in start_command
if debug_level() > 0:
File
line 1517, in debug_level
_debug_level = int(gisenv().get('DEBUG', 0))
File
line 934, in gisenv
File
line 445, in read_command
return handle_errors(returncode, stdout, args, kwargs)
File
line 312, in handle_errors
returncode=returncode)
grass.exceptions.CalledModuleError: Module run None ['g.gisenv', '-n']
ended with error
Process ended with non-zero return code -5. See errors in the (error)
output.
Error in GUI startup. If necessary, please report this error to the GRASS
developers.
Switching to text mode now.
Hit RETURN to continue...
File "/Applications/GRASS-7.0.app/Contents/MacOS/grass70", line 1438, in
<module>
set_data()
File "/Applications/GRASS-7.0.app/Contents/MacOS/grass70", line 681, in
set_data
gui_startup(grass_gui == 'gtext')
File "/Applications/GRASS-7.0.app/Contents/MacOS/grass70", line 703, in
gui_startup
os.execlp(cmd_name, "-text")
File
"/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/os.py",
line 329, in execlp
execvp(file, args)
File
line 346, in execvp
_execvpe(file, args)
File
line 382, in _execvpe
func(fullname, *argrest)
OSError: [Errno 2] No such file or directory
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
Ticket URL: <https://trac.osgeo.org/grass/ticket/2942>
