[GRASS-dev] [GRASS GIS] #2865: Error when installing r.modis add-on and warning when starting grass
trac at osgeo.org
Mon Feb 29 07:25:54 PST 2016
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Addons | Version: svn-trunk
Resolution: | Keywords: r.modis
CPU: x86-64 | Platform: Linux
Comment (by Veroandreo):
Just an update:
Somewhere in the way between r67891 (the last ticket I opened) and r67965
that I'm using now, the warning when opening grass dissapeared but the
other issue (the serious one) remains. I tried removing r.modis and
installing back and here's the output:
GRASS 7.1.svn (latlong_wgs84):~ > g.extension r.modis
Fetching <r.modis> from GRASS GIS Addons repository (be patient)...
Compiling...
File
"/tmp/grass7-veroandreo-20256/tmp8pdvRv/r.modis/scripts/r.modis.download",
line 94, in <module>
from rmodislib import product
ImportError: No module named rmodislib
make[1]: *** [r.modis.download.tmp.html] Error 1
File
"/tmp/grass7-veroandreo-20256/tmp8pdvRv/r.modis/scripts/r.modis.import",
line 100, in <module>
from rmodislib import resampling, product, projection, get_proj
make[1]: *** [r.modis.import.tmp.html] Error 1
Installing...
/usr/bin/install: cannot stat
‘/tmp/grass7-veroandreo-20256/tmp8pdvRv/r.modis/docs/html/r.modis.download.html’:
No such file or directory
make[1]: *** [install] Error 1
‘/tmp/grass7-veroandreo-20256/tmp8pdvRv/r.modis/docs/html/r.modis.import.html’:
Updating addons metadata file...
Installation of <r.modis> successfully finished
same as originally reported... the effect is that when I call modules'
user interfaces they do not contain the "Manual page" (See attached .png).
I do get help if I use nameofmodule --h
Ticket URL: <https://trac.osgeo.org/grass/ticket/2865#comment:8>
