[GRASS-dev] [GRASS GIS] #2936: v.net.distance: wrong directions in one-way streets
trac at osgeo.org
Mon Feb 29 14:42:40 PST 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Vector | Version: svn-trunk
Resolution: | Keywords: v.net.distance network one-way
CPU: | direction
Unspecified | Platform: Unspecified
Comment (by mmetz):
Manual:
"Each path consist of several lines. If a line is on the shortest path
from a point then the category of this point is assigned to the line. Note
that every line may contain more than one category value since a single
line may be on the shortest path for more than one from feature."
That means lines are copied directly from input to output, line directions
are not adjusted and lines are not merged to unique paths for each `from`
category.
Unfortunately, the paths as reported by v.net.distance (irrespective of
the direction) are wrong: the shortest path from 7779 to 7780 should take
the long route, and the shortest path from 7780 to 7779 should take the
short route. Fixing this bug would require a new function in
lib/vector/neta. Hopefully the dglib interface allows for an easy solution
to provide an inverse to
lib/vector/neta/path.c:NetA_distance_from_points().
This ticket should be closed and a new ticket should be opened that
v.net.distance calculates paths in reverse (from to to from instead of
from from to to).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2936#comment:1>
