[GRASS-dev] [GRASS GIS] #2804: pattern option for t.list and t.remove
trac at osgeo.org
Thu Feb 25 09:18:18 PST 2016
Reporter: veroandreo | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.4
Component: Temporal | Version: unspecified
Resolution: | Keywords: t.list, t.remove
CPU: Unspecified | Platform: Linux
Comment (by lucadelu):
Soeren (and all) I looked into code of t.list and I discovered two
possible way to implement this:
- simpler add into get_dataset_list function a LIKE operetor passing the
pattern string
- more complex using the python fnmatch module to fetch the right
databases, but in this case we should get always the name of dataset in
the query and later check if it is a required column otherwise not
print/write the field
What do you suggest? (also other ways are welcome)
Solving the list problem also the remove one should be simpler to
implement.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2804#comment:2>
