[GRASS-dev] [GRASS GIS] #2851: v.in.ogr: imports empty values as empty strings instead of NULL values
GRASS GIS trac at osgeo.org
Wed Jan 6 09:59:41 PST 2016
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.0.3
 Component:  Default      |    Version:  svn-trunk
Resolution:               |   Keywords:  vector v.in.ogr null
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by marisn):
 Although I am more purist and would say that NULL should be NULL, here's
 opinion why "no data" should be text (from Django framework):
 "Avoid using null on string-based fields such as CharField and TextField
 because empty string values will always be stored as empty strings, not as
 NULL. If a string-based field has null=True, that means it has two
 possible values for “no data”: NULL, and the empty string. In most cases,
 it’s redundant to have two possible values for “no data;” the Django
 convention is to use the empty string, not NULL."
 https://docs.djangoproject.com/en/1.9/ref/models/fields/#null
 If it comes down to voting, my vote goes for keeping NULL as NULL (do not
 alter data unless asked for).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2851#comment:2>
