[GRASS-dev] [GRASS GIS] #2851: v.in.ogr: imports empty values as empty strings instead of NULL values
trac at osgeo.org
Thu Jan 7 04:37:32 PST 2016
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: Default | Version: svn-trunk
Resolution: | Keywords: vector v.in.ogr null
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:2 marisn]:
> Although I am more purist and would say that NULL should be NULL, here's
opinion why "no data" should be text (from Django framework):
> "Avoid using null on string-based fields such as CharField and TextField
because empty string values will always be stored as empty strings, not as
NULL. If a string-based field has null=True, that means it has two
possible values for “no data”: NULL, and the empty string. In most cases,
it’s redundant to have two possible values for “no data;” the Django
convention is to use the empty string, not NULL."
> https://docs.djangoproject.com/en/1.9/ref/models/fields/#null
> If it comes down to voting, my vote goes for keeping NULL as NULL (do
not alter data unless asked for).
I agree with you. NULL is a concept that is different from the empty
string, even though in some cases they are equivalent (e.g. AFAIK there is
no way to distinguish between the two in a csv file...).
In the case of this specific bug the issue is specifically for date fields
which, IIUC, are only supported as such in OGR since 1.3 (but even Debian
Squeeze, aka oldoldstable is beyond that version, so that should not be an
issue). So a compromise solution could be to nullify the date and time
fields (i.e. the first change in the patch), but not the string fields.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2851#comment:3>
