[GRASS-dev] [GRASS GIS] #2385: v.in.ogr doesn't use information from dblogin file about external PostgreSQL server
trac at osgeo.org
Thu Jan 7 03:05:26 PST 2016
PostgreSQL server
Reporter: hemeybo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Database | Version: svn-releasebranch70
Resolution: | Keywords: v.in.ogr PostgreSQL db.login
| db.databases
CPU: x86-64 | Platform: Linux
Comment (by martinl):
I have implemented experimental support for `db.login` settings to
`v.in.ogr` and `v.external` in r67510. There is unfortunately a duplicated
code (`dsn.c`) which would be probably good to move to Vlib to avoid code
duplication. We will need similar code for `v.out.ogr`, `v.out.postgis`
and `v.external.out`. These modules already contain a duplicated code
(list layers). It would make sense to move this duplicated code to the
library (a new one, eg. `libgrass_gdal`) or to Vlib.
Similar situation for `r.in.gdal`, `r.external` and `r.external.out`. From
this point of view a new library which would provide listing layers (both
raster and vector), setting datasource would make more sense.
What do you think? Better ideas?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2385#comment:5>
