[GRASS-dev] [GRASS GIS] #2854: results in winGRASS7 32bit vs 64bit: should they be identical?
trac at osgeo.org
Mon Jan 11 12:23:08 PST 2016
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: Raster | Version: svn-releasebranch70
Resolution: | Keywords:
CPU: x86-64 | Platform: MSWindows 7
Comment (by glynn):
Replying to [comment:7 neteler]:
> Doesn't this qualify for "basically identical results as much as
different architectures can achieve"?
In theory, it should be possible to obtain identical results on any
architecture using IEEE-754 floating-point for calculations using only +,
-, *, / and sqrt() (no transcendental functions such as sin, cos, log,
exp, etc). But that may have a noticeable performance cost (e.g. using
-ffloat-store to discard excess precision, forgoing certain optimisations,
etc).
Regarding the use of an "epsilon":
1. The accuracy of a floating-point value is proportional to its
magnitude. For IEEE-754, FLT_EPSILON is ~1.192e-7 while DBL_EPSILON is
~2.22e-16. This represents the difference between 1.0 and the smallest
distinct, representable value greater than 1.0.
Consequently, it provides a measure of the worst-case rounding error for
values between 1.0 (inclusive) and 2.0 (exclusive). For round-to-nearest,
the worst-case rounding error will be plus or minus half that value. For
larger or smaller values, the maximum rounding error will be scaled
accordingly. I.e. a typical "tolerant comparison" would be along the lines
of
if (fabs(a-b) < N * epsilon * max(fabs(a),fabs(b))) ...
2. Rounding error occurs at each stage in the computation. The expected
absolute error for a complex calculation will be at least the sum of the
absolute errors for the individual steps.
3. When subtractions are involved, you can't rely upon the absolute error
in the result being proportional to the magnitude of the result, as
subtracting similar values will produce a result whose magnitude may be
much smaller than either of the individual values, but whose absolute
error is proportional to that of the individual values.
(A concrete example of that last point is that a single-pass variance
calculation using sum-of-squares minus sum-squared can yield a negative
value for the variance if the deviations are small relative to the mean).
4. Other common cases where the accuracy of the result can be far worse
than that of intermediate results or the inputs include finding roots of
high-degree polynomials
([https://en.wikipedia.org/wiki/Wilkinson's_polynomial an extreme
example]) and acos(x) where x is close to 1.0 (as x tends to 1.0, the
derivative of acos(x) tends to infinity while acos(x) itself tends to
zero; the first magnifies the absolute error while the second further
magnifies the relative error).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2854#comment:9>
