[GRASS-dev] [GRASS GIS] #2814: digitizer crashes, leaves vector broken
trac at osgeo.org
Thu Jan 7 09:47:37 PST 2016
Reporter: harrikoo | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.3
Component: wxGUI | Version: 7.0.2
Resolution: | Keywords: digitizer, vector
CPU: Unspecified | Platform: Unspecified
Comment (by martinl):
Replying to [ticket:2814 harrikoo]:
> I have yet to build a case where this manifests consistently, but it has
appeared several times. I describe some features of the defect:
> 1. Usually happens when crossing lines and boundaries: moving vertices
around so that existing lines cross, thus creating new lines/areas. But
not always; I haven't found a regular pattern yet.
> 2. digitizer crashes immeadiately, as does wxgui
I am not sure of originally reported issue is fixed (there is no undo
mentioned)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2814#comment:14>
