[GRASS-dev] [GRASS GIS] #2814: digitizer crashes, leaves vector broken
trac at osgeo.org
Fri Jan 8 01:56:04 PST 2016
Reporter: harrikoo | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.3
Component: wxGUI | Version: 7.0.2
Resolution: | Keywords: digitizer, vector
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:14 martinl]:
> Replying to [ticket:2814 harrikoo]:
> > I have yet to build a case where this manifests consistently, but it
has appeared several times. I describe some features of the defect:
> > 1. Usually happens when crossing lines and boundaries: moving vertices
around so that existing lines cross, thus creating new lines/areas. But
not always; I haven't found a regular pattern yet.
> > 2. digitizer crashes immeadiately, as does wxgui
> I am not sure of originally reported issue is fixed (there is no undo
mentioned)
I've tried to reproduce, but can't. We would need a reproducible
example...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2814#comment:15>
