[GRASS-dev] [GRASS GIS] #2814: digitizer crashes, leaves vector broken
Harri Kiiskinen
harkiisk at gmail.com
Fri Jan 8 02:06:36 PST 2016
Subject: Re: [GRASS GIS] #2814: digitizer crashes, leaves vector broken
Date: Fri, 08 Jan 2016 09:56:04 -0000
> Reporter: harrikoo | Owner: grass-dev@…
> Type: defect | Status: new
> Priority: blocker | Milestone: 7.0.3
> Component: wxGUI | Version: 7.0.2
> Resolution: | Keywords: digitizer, vector
> CPU: Unspecified | Platform: Unspecified
> Comment (by mlennert):
> Replying to [comment:14 martinl]:
> > Replying to [ticket:2814 harrikoo]:
> > > I have yet to build a case where this manifests consistently, but it
> has appeared several times. I describe some features of the defect:
> > > 1. Usually happens when crossing lines and boundaries: moving vertices
> around so that existing lines cross, thus creating new lines/areas. But
> not always; I haven't found a regular pattern yet.
> > > 2. digitizer crashes immeadiately, as does wxgui
> > I am not sure of originally reported issue is fixed (there is no undo
> mentioned)
> I've tried to reproduce, but can't. We would need a reproducible
> example...
I've been trying to comment on this one, but the Trac login does not
work, so I can't get into the system.
I've been following the discussion with interest. I could reproduce
the bugs discovered by 'mlennert', but the results were not the same:
the coor file did have extra data, but could be opened with
g.gui.vdigit, after which the file was quite ok.
Good to have these bugs fixed, too; but in the original cases, the
resulting vector was in such a state, that g.gui.vdigit was not able
to open it any more.
But as I wrote, I have not been able to create a reproducible example;
but the exactly same phenomenon has happened a few times during the
last two months I've been using the g.gui.vdigit extensively. Now that
I know what to wait for, I'll try to figure out what exactly I did
before the crash next time. (g.gui.vdigit does crash quite a lot, but
usually the results are harmless.)
Best,
Harri K.
