[GRASS-dev] [GRASS GIS] #2845: Build failure with 7.0.3RC1 on Linux
trac at osgeo.org
Fri Jan 8 07:31:00 PST 2016
Reporter: scimmia | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.3
Component: Compiling | Version: unspecified
Resolution: | Keywords:
CPU: x86-64 | Platform: Linux
Comment (by neteler):
Replying to [comment:25 martinl]:
> No, `svn status` will report these files after you run `svn propdel
svn:ignore gui/wxpython/xml`.
OK, so let's apply that to SVN!
> But I still don't understand what's the point.
Simple: the "make clean" may be interrupted, so garbarge remains and
goes, as we have just seen above, unnoticed into the source tarball. This
I want to avoid in future.
Solution: make the garbage visible in "svn status" since I run that prior
to package the source tarball. Whatever leftover doesn't show up will be
published. And cause tickets like this one :-)
If you disagree (no problem) close the ticket as done since I updated the
release procedure to include extra leftover collection in r67511, r67512.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2845#comment:26>
