[GRASS-dev] [GRASS GIS] #2845: Build failure with 7.0.3RC1 on Linux
trac at osgeo.org
Fri Jan 8 07:35:35 PST 2016
Reporter: scimmia | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.3
Component: Compiling | Version: unspecified
Resolution: | Keywords:
CPU: x86-64 | Platform: Linux
Comment (by wenzeslaus):
Replying to [comment:26 neteler]:
> Simple: the "make clean" may be interrupted, so garbarge remains and
goes, as we have just seen above, unnoticed into the source tarball. This
I want to avoid in future.
> Solution: make the garbage visible in "svn status" since I run that
prior to package the source tarball. Whatever leftover doesn't show up
will be published.
It's hard for me to tell what's right at this point but the `OBJ.*` are
generated during compilation and ignored by `svn status`, so shouldn't be
the desired behavior the same for all the generated files. Or should go
all the generated files to `OBJ.*` dirs?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2845#comment:27>
