[GRASS-dev] Max Memory usage limit
Panagiotis Mavrogiorgos
pmav99 at gmail.com
Wed Jan 13 00:28:33 PST 2016
On Tue, Jan 12, 2016 at 10:20 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Jan 11, 2016 at 8:04 PM, Panagiotis Mavrogiorgos
> <pmav99 at gmail.com> wrote:
> > Hi all,
> > Just out of curiosity, why is there an upper limit to the memory we can
> use
> > on operations like r.in.gdal?
> The question is too generic, so I'll refer to r.in.gdal only:
> To my knowledge there is a GDAL imposed CACHE limit
> https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.in.gdal/main.c#L271
> 271 /* default GDAL memory cache size appears to be only 40 MiB,
> slowing down r.in.gdal */
> 272 if (parm.memory->answer && *parm.memory->answer) {
> 273 /* TODO: GDALGetCacheMax() overflows at 2GiB, implement
> use of GDALSetCacheMax64() */
> 274 GDALSetCacheMax(atol(parm.memory->answer) * 1024 * 1024);
> but concerning the data you can import I am not aware of any limit.
> Maybe this page is of interest to you:
> https://grasswiki.osgeo.org/wiki/Large_raster_data_processing
> What is exactly your problem you encountered?
Thank you Marcus,
That was really helpful. I don't have a particular problem. I just found
strange that the limit was so low on x64 architectures.
with kind regards,
Panos
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160113/332dffd6/attachment.html>
