[GRASS-dev] strange behavior of gselect.Select
Anna Petrášová
kratochanna at gmail.com
Wed Jan 13 19:07:20 PST 2016
On Tue, Jan 12, 2016 at 7:50 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> Hi,
> Anna sorry for the delay in the answer
> On 30 December 2015 at 16:51, Anna Petrášová <kratochanna at gmail.com>
> wrote:
> > The TextCtrl must have wx.TE_PROCESS_ENTER style set, that might be the
> > problem.
> ok, in my case I'm speaking about a wx.combo.ComboCtrl but probably is
> the same. Could I add an option style (set by default to None) in
> Select class of gselect.py?
> Yes. I have some doubts it will work consistently across all platforms,
but I can test on Windows if you need.
> > I was dealing with this by checking the existence of the typed map after
> > every typed letter. This can slow it down little bit during typing, so I
> am
> > not sure which solution is actually better. With the event bound to
> Enter,
> > users sometimes don't understand they have to press Enter.
> I agree with this, I also have no clear idea about the better
> solution, other opinions?
> > Anna
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160113/10b359db/attachment.html>
