[GRASS-dev] strange behavior of gselect.Select
Luca Delucchi
lucadeluge at gmail.com
Thu Jan 14 00:50:08 PST 2016
On 14 January 2016 at 04:07, Anna Petrášová <kratochanna at gmail.com> wrote:
>> ok, in my case I'm speaking about a wx.combo.ComboCtrl but probably is
>> the same. Could I add an option style (set by default to None) in
>> Select class of gselect.py?
> Yes. I have some doubts it will work consistently across all platforms, but
> I can test on Windows if you need.
Yes please, could you test the attached diff on Windows?
Is there anyone could test it also on mac?
I tested it on Linux/Debian with wx python version 3.0.1.1 and it
works correctly.
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
Index: gui/wxpython/gui_core/gselect.py
--- gui/wxpython/gui_core/gselect.py (revision 67560)
+++ gui/wxpython/gui_core/gselect.py (working copy)
@@ -79,7 +79,7 @@
type = None, multiple = False, nmaps = 1,
mapsets = None, updateOnPopup = True, onPopup = None,
fullyQualified = True, extraItems = {}, layerTree = None,
- validator = wx.DefaultValidator):
+ validator = wx.DefaultValidator, style = 0):
"""Custom control to create a ComboBox with a tree control to
display and select GIS elements within acessible mapsets.
Elements can be selected with mouse. Can allow multiple
@@ -97,12 +97,13 @@
:param layerTree: show only elements from given layer tree if not None
:param validator: validator for TextCtrl
- wx.combo.ComboCtrl.__init__(self, parent=parent, id=id, size=size, validator=validator)
+ wx.combo.ComboCtrl.__init__(self, parent=parent, id=id, size=size,
+ validator=validator, style=style)
if globalvar.CheckWxVersion([3]):
self.SetName("Select")
else:
self.GetChildren()[0].SetName("Select")
self.GetChildren()[0].type = type
self.tcp = TreeCtrlComboPopup()
@@ -291,7 +292,7 @@
def OnKeyUp(self, event):
"""Enable to select items using keyboard.
Unused with wxPython 3, can be removed in the future.
item = self.seltree.GetSelection()
@@ -436,7 +437,7 @@
# get current mapset
curr_mapset = grass.gisenv()['MAPSET']
# map element types to g.list types
elementdict = {'cell': 'raster',
'raster': 'raster',
@@ -589,7 +590,7 @@
"""Enables to select items using keyboard
- Unused with wxPython 3, can be removed in the future.
+ Unused with wxPython 3, can be removed in the future.
@@ -1358,7 +1359,7 @@
else:
extList = vectorFormatExtension
fileMask += '%(name)s (*.%(low)s;*.%(up)s)|*.%(low)s;*.%(up)s|' % {'name': 'ESRI Shapefile', 'low': 'shp', 'up': 'SHP'}
for name, ext in sorted(extList.items()):
if name in ('ESRI Shapefile', 'GeoTIFF'):
continue
@@ -1435,7 +1436,7 @@
startDirectory=os.getcwd(),
changeCallback=self.OnUpdate)
browse.GetChildren()[1].SetName('GdalSelectDataSource')
self.dbWidgets['browse'] = browse
self.dbWidgets['choice'] = wx.Choice(parent=self.dbPanel, name='GdalSelectDataSource')
self.dbWidgets['choice'].Bind(wx.EVT_CHOICE, self.OnUpdate)
@@ -1786,7 +1787,7 @@
settingsFile = os.path.join(GetSettingsPath(), 'wxOGR')
else:
settingsFile = os.path.join(GetSettingsPath(), 'wxGDAL')
self.settsManager = ManageSettingsWidget(parent=self,
settingsFile=settingsFile)
self.settsManager.settingsChanged.connect(self.OnSettingsChanged)
@@ -1924,7 +1925,7 @@
# v.external returns info for individual bands, however projection is shared by all bands ->
# (it is possible to take first line)
lines = ret.splitlines()
projectionMatch = '0'
if lines:
@@ -1987,7 +1988,7 @@
listData.append((layerId, baseName, projectionMatchCaption, grassName))
data.append((layerId, baseName, int(projectionMatch), grassName))
layerId += 1
# emit signal
self.reloadDataRequired.emit(listData=listData, data=data)
@@ -2317,16 +2318,16 @@
self.task=task
self.parent = parent
self.giface = giface
self.selectedFeatures = None
self.registered = False
self._vectorSelect = None
self.mapdisp = self.giface.GetMapDisplay()
self.catsField = wx.TextCtrl(parent=self, id=wx.ID_ANY,
size=globalvar.DIALOG_TEXTCTRL_SIZE)
icon = wx.Bitmap(os.path.join(globalvar.ICONDIR, "grass", "select.png"))
self.buttonVecSelect = buttons.ThemedGenBitmapToggleButton(parent=self, id=wx.ID_ANY,
bitmap=icon,
@@ -2333,13 +2334,13 @@
size=globalvar.DIALOG_COLOR_SIZE)
self.buttonVecSelect.Bind(wx.EVT_BUTTON, self._onClick)
if self.mapdisp:
switcher = self.mapdisp.GetToolSwitcher()
switcher.AddCustomToolToGroup(group='mouseUse',
btnId=self.buttonVecSelect.GetId(),
toggleHandler=self.buttonVecSelect.SetValue)
self._layout()
def _isMapSelected(self):
@@ -2350,7 +2351,7 @@
if layerSelected is None:
GWarning(_("No vector map selected in layer manager. Operation canceled."))
return False
return True
def _chckMap(self):
@@ -2398,7 +2399,7 @@
def OnClose(self, event=None):
if not self.mapdisp:
return
switcher.RemoveCustomToolFromGroup(self.buttonVecSelect.GetId())
if self._vectorSelect is not None:
Index: gui/wxpython/tplot/frame.py
--- gui/wxpython/tplot/frame.py (revision 67560)
+++ gui/wxpython/tplot/frame.py (working copy)
@@ -51,6 +51,7 @@
from core import globalvar
from grass.pygrass.vector.geometry import Point
from grass.pygrass.raster import RasterRow
+from grass.pygrass.gis.region import Region
from collections import OrderedDict
from subprocess import PIPE
try:
@@ -107,6 +108,7 @@
self.dbif = tgis.SQLDatabaseInterfaceConnection()
self.dbif.connect()
self.Bind(wx.EVT_CLOSE, self.onClose)
+ self.region = Region()
def init(self):
self.timeDataR = OrderedDict()
@@ -214,12 +216,19 @@
self.datasetSelectLabelV = wx.StaticText(parent=self.controlPanelVector,
id=wx.ID_ANY,
label=_('Vector temporal '
- 'dataset (strds)'))
+ 'dataset (strds)\n'
+ 'Please press enter if'
+ ' you digit the name'
+ ' instead select with'
+ ' combobox'))
self.datasetSelectV = gselect.Select(parent=self.controlPanelVector,
id=wx.ID_ANY,
size=globalvar.DIALOG_GSELECT_SIZE,
- type='stvds', multiple=True)
- self.datasetSelectV.Bind(wx.EVT_TEXT, self.OnVectorSelected)
+ type='stvds', multiple=True,
+ style=wx.TE_PROCESS_ENTER)
+ self.datasetSelectV.Bind(wx.EVT_TEXT_ENTER, self.OnVectorSelected)
+ self.datasetSelectV.Bind(wx.EVT_COMBOBOX_CLOSEUP,
+ self.OnVectorSelected)
self.attribute = gselect.ColumnSelect(parent=self.controlPanelVector)
self.attributeLabel = wx.StaticText(parent=self.controlPanelVector,
@@ -281,6 +290,10 @@
"""Load data and read properties
:param list timeseries: a list of timeseries
+ if not self.poi:
+ GError(parent=self, message=_("Invalid input coordinates"),
+ showTraceback=False)
+ return
mode = None
unit = None
columns = ','.join(['name', 'start_time', 'end_time'])
@@ -683,6 +696,12 @@
return
+ bbox = self.region.get_bbox()
+ if not bbox.contains(self.poi):
+ GError(parent=self, message=_("Seed point outside the "
+ "current region"),
+ return
# check raster dataset
if datasetsR:
datasetsR = datasetsR.split(',')
@@ -838,11 +857,20 @@
def OnVectorSelected(self, event):
"""Update the controlbox related to stvds"""
dataset = self.datasetSelectV.GetValue().strip()
- vect_list = grass.read_command('t.vect.list', flags='s', input=dataset,
- col='name')
- vect_list = list(set(sorted(vect_list.split())))
- for vec in vect_list:
- self.attribute.InsertColumns(vec, 1)
+ if dataset:
+ try:
+ vect_list = grass.read_command('t.vect.list', flags='s',
+ input=dataset, column='name')
+ except Exception:
+ self.attribute.Clear()
+ GError(parent=self, message=_("Invalid input temporal dataset"),
+ return
+ vect_list = list(set(sorted(vect_list.split())))
+ for vec in vect_list:
+ self.attribute.InsertColumns(vec, 1)
+ else:
+ return
class LookUp:
