[GRASS-dev] eval option in r.mapcalc in a python script
Paulo van Breugel
p.vanbreugel at gmail.com
Thu Jan 14 04:05:07 PST 2016
On 14-01-16 09:57, Moritz Lennert wrote:
> On 14/01/16 09:34, Paulo van Breugel wrote:
>> From the r.mapcalc manual, the 'eval' option is described to run more
>> complex expressions. But I wonder how I apply the example below in a
>> python script?
>> eval(elev_200 = elevation - 200, \
>> elev_5 = 5 * elevation, \
>> elev_p = pow(elev_5, 2))
>> elevation_result = (0.5 * elev_200) + 0.8 * elev_p
> Can't you just put the above in a string variable and feed it to the
> 'expression' parameter of grass.mapcalc (or alternatives
> grass.run_command('r.mapcalc', ...)?
Thanks, I'll try that
>> Somewhat related, if I have a large number of maps. For each map I need
>> to compute a value. At the end, the resulting maps need to be summed up.
>> One way is to run a loop, and use r.series to sum up the results. E.g.,
>> for i in xrange(len(IN)):
>> out = 'shi' + str(i)
>> out.append(out)
>> grass.mapcalc("$out = log($in)", out=out[i], in=in[i])
>> grass.run_command("r.series", output="endresult", input=out,
>> method="sum")
>> This generates a lot of intermediate layers, which can potentially take
>> up a lot of space on HD. To avoid that, I could do
>> grass.mapcalc("$out = 0", out=out)
>> grass.mapcalc("$out = $out + log($in)", out=out, in=in[i]),
>> overwrite=True
> ISTR that modifying the contents of a map in-place might be possible,
> but not recommended.
I think your solution below is perfectly fine, but out of curiosity, and
to get a better grasp of the possible pitfalls, what is the reason the
above in-place modification is not recommended?
> As a compromose you could do something like this:
> grass.mapcalc("$oldout = 0")
> grass.mapcalc("$newout = $oldout + log($in)", out=out, in=in[i])
> grass.run_command('g.rename', '$newout,$oldout', overwrite=True)
>> An alternative is to construct one large expression along the lines of
>> expression = "log(in[1]) + log(in[2] + ....". I assume this will be
>> faster? It would result in a unwieldy large expression though, and I
>> remember something about a limit to the length of the expression? So
>> that is why I wonder if using the 'eval' option would be useful.
>> Any tips for the best approach?
> Maybe one option, as I could image others to have this kind of issue,
> would be to add a "modifier" (or similar name) parameter to r.series
> which would allow to calculate the statistic defined by "method" on a
> modified version of the maps (e.g. squared, square root, log, sin,
> cos, etc.).
The log in the example above was for illustrative purposes, the real
expression is a bit more complex. Nevertheless, I think it would be very
useful to have such a modifier, really good idea!
> Moritz
