[GRASS-dev] eval option in r.mapcalc in a python script
Moritz Lennert mlennert at club.worldonline.be
Thu Jan 14 04:54:58 PST 2016
On 14/01/16 13:05, Paulo van Breugel wrote:
>>> grass.mapcalc("$out = 0", out=out)
>>> for i in xrange(len(IN)):
>>>      grass.mapcalc("$out = $out + log($in)", out=out, in=in[i]),
>>> overwrite=True
>> ISTR that modifying the contents of a map in-place might be possible,
>> but not recommended.
> I think your solution below is perfectly fine, but out of curiosity, and
> to get a better grasp of the possible pitfalls, what is the reason the
> above in-place modification is not recommended?
See Glynn's comment (to you ;-) ) here
http://lists.osgeo.org/pipermail/grass-dev/2015-December/077600.html
>> Maybe one option, as I could image others to have this kind of issue,
>> would be to add a "modifier" (or similar name) parameter to r.series
>> which would allow to calculate the statistic defined by "method" on a
>> modified version of the maps (e.g. squared, square root, log, sin,
>> cos, etc.).
> The log in the example above was for illustrative purposes, the real
> expression is a bit more complex. Nevertheless, I think it would be very
> useful to have such a modifier, really good idea!
Try the attached patch, which is just a brute-force, proof-of-concept.
It would be nicer to solve this with function pointers, but I'm not at
ease with that, so I'll leave that to others.
If you would like to see this implemented, I suggest filing an
enhancement ticket. You can attach this patch if you want to.
Moritz
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160114/a2b7f8ac/attachment.bin>
