[GRASS-dev] [GRASS GIS] #2868: v.in.ogr Segmentation fault
trac at osgeo.org
Fri Jan 15 02:59:49 PST 2016
Reporter: DmitryKolesov | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
I got segmentation fault in `v.in.ogr` module with `-t` flag. To reproduce
it, type the next lines (in Lat-Lon location):
> g.version -r
GRASS 7.0.3svn (2016)
libgis Revision: 67364
libgis Date: 2015-12-24 18:07:44 +0300
> echo '{"type": "MultiPolygon", "coordinates": [[[[41.16783751473027,
49.18823659816202], [41.17928406367621, 49.19697811717231],
[41.18910195623221, 49.18532946770238], [41.204306122079,
49.16872544901082], [41.19158201698379, 49.1659820458448],
[41.18895894443899, 49.16549865975956], [41.18763568560129,
49.16499058729008], [41.16783751473027, 49.18823659816202]]]]}' >
test.geojson
> v.in.ogr -t input=test.geojson layer=OGRGeoJSON out=tmp --o
Check if OGR layer <OGRGeoJSON> contains polygons...
100%
Importing 1 features (OGR layer <OGRGeoJSON>)...
100%
Registering primitives...
Number of nodes: 1
Number of primitives: 2
Number of points: 0
Number of lines: 0
Number of boundaries: 1
Number of centroids: 1
Number of areas: 1
Number of isles: 1
Segmentation fault (core dumped)
But the map is created:
> v.out.ascii tmp format=wkt
POLYGON((41.16783751 49.18823660, 41.17928406 49.19697812, 41.18910196
49.18532947, 41.20430612 49.16872545, 41.19158202 49.16598205, 41.18895894
49.16549866, 41.18763569 49.16499059, 41.16783751 49.18823660))
PS If I don't use `-t` flag the error doesn't appear.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2868>
