[GRASS-dev] [GRASS GIS] #2868: v.in.ogr Segmentation fault
GRASS GIS trac at osgeo.org
Fri Jan 15 03:05:21 PST 2016
  Reporter:  DmitryKolesov  |      Owner:  grass-dev@…
      Type:  defect         |     Status:  new
  Priority:  normal         |  Milestone:  7.0.3
 Component:  Vector         |    Version:  svn-releasebranch70
Resolution:                 |   Keywords:  v.in.ogr
       CPU:  Unspecified    |   Platform:  Unspecified
Changes (by neteler):
 * keywords:   => v.in.ogr
 * version:  unspecified => svn-releasebranch70
 * component:  Default => Vector
Old description:
> I got segmentation fault in `v.in.ogr` module with `-t` flag. To
> reproduce it, type the next lines (in Lat-Lon location):
> > g.version -r
> GRASS 7.0.3svn (2016)
> libgis Revision: 67364
> libgis Date: 2015-12-24 18:07:44 +0300
> > echo '{"type": "MultiPolygon", "coordinates": [[[[41.16783751473027,
> 49.18823659816202], [41.17928406367621, 49.19697811717231],
> [41.18910195623221, 49.18532946770238], [41.204306122079,
> 49.16872544901082], [41.19158201698379, 49.1659820458448],
> [41.18895894443899, 49.16549865975956], [41.18763568560129,
> 49.16499058729008], [41.16783751473027, 49.18823659816202]]]]}' >
> test.geojson
> > v.in.ogr -t input=test.geojson layer=OGRGeoJSON out=tmp --o
>  Check if OGR layer <OGRGeoJSON> contains polygons...
>  100%
>  Importing 1 features (OGR layer <OGRGeoJSON>)...
>  100%
>  Registering primitives...
>  Number of nodes: 1
>  Number of primitives: 2
>  Number of points: 0
>  Number of lines: 0
>  Number of boundaries: 1
>  Number of centroids: 1
>  Number of areas: 1
>  Number of isles: 1
>  Segmentation fault (core dumped)
> But the map is created:
> > v.out.ascii tmp format=wkt
> POLYGON((41.16783751 49.18823660, 41.17928406 49.19697812, 41.18910196
> 49.18532947, 41.20430612 49.16872545, 41.19158202 49.16598205,
> 41.18895894 49.16549866, 41.18763569 49.16499059, 41.16783751
> 49.18823660))
> PS If I don't use `-t` flag the error doesn't appear.
New description:
 I got segmentation fault in `v.in.ogr` module with `-t` flag. To reproduce
 > g.version -r
 test.geojson
  100%
  100%
  Number of nodes: 1
  Number of points: 0
  Number of lines: 0
  Number of areas: 1
  Number of isles: 1
 49.18532947, 41.20430612 49.16872545, 41.19158202 49.16598205, 41.18895894
 49.16549866, 41.18763569 49.16499059, 41.16783751 49.18823660))
Ticket URL: <https://trac.osgeo.org/grass/ticket/2868#comment:1>
