[GRASS-dev] GRASS on OS X El Capitan - slowly dying or is something happening?
Rainer M Krug Rainer at krugs.de
Thu Jan 21 01:01:56 PST 2016
William Kyngesburye <woklist at kyngchaos.com> writes:
> There are a couple ideas floating around.
> I'm surprised Homebrew has a problem.  Since it would leave everything
> in the configured location (/usr/local), there should not be library
> paths pointing somewhere else that would need DYLD_LIBRARY_PATH to
> divert.
homebrew is compiling in a temporary location, and than installing it to
/usr/local/Cellar/.
The problem is the same why I had to install and than compile again:
| bash-4.3$ make
| if [ "/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/scripts/d.out.file" != "" ] ; then GISRC=/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/demolocation/.grassrc70 GISBASE=/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0 PATH="/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/bin:/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/bin:/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/scripts:$PATH" PYTHONPATH="/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/etc/python:/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/gui/wxpython:$PYTHONPATH" DYLD_LIBRARY_PATH="/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/bin:/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/scripts:/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/lib:/private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/lib:" LC_ALL=C /private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/scripts/d.out.file --html-description < /dev/null | grep -v '</body>\|</html>' > d.out.file.tmp.html ; fi
| dyld: Library not loaded: /usr/local/Cellar/grass-70/7.0.1/grass-7.0.1/lib/libgrass_gis.7.0.1.dylib
|   Referenced from: /private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/bin/g.parser
|   Reason: image not found
| make: *** [d.out.file.tmp.html] Error 1
| rm d.out.file.tmp.html
| bash-4.3$
During make, the html documentation is created. For this,
libgrass_gis.7.0.1.dylib is needed. It is already compiled, but not
installed.
It is in
| bash-4.3$ ls -la /private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/lib/libgrass_gis*
| -rwxr-xr-x  1 rainerkrug  wheel  218244 Jan 21 09:37 /private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/lib/libgrass_gis.7.0.1.dylib
| lrwxr-xr-x  1 rainerkrug  wheel      24 Jan 21 09:37 /private/tmp/grass-7020160121-38274-ed29gx/grass-7.0.1/dist.x86_64-apple-darwin15.2.0/lib/libgrass_gis.dylib -> libgrass_gis.7.0.1.dylib
| bash-4.3$
And I assume the path where it is located is in the DYNLIB_ variable
which is ignored.
This problem should be solvable, when somehow the path to the compiled
(but not installed) could be temporarily added during the make.
Any suggestions how this could be done?
Rainer
>> On Jan 20, 2016, at 8:37 AM, Rainer M Krug <Rainer at krugs.de> wrote:
>> Hi
>> Sorry for this blunt subject - but I am wondering if anybody is looking
>> at supporting El Capitan without having to disable SIP (System Integrity
>> Protection). SIP is likely to stay, and for many (including myself)
>> disabling SIP is not really an option as it goes to deep into the OS.
>> So my personal opinion: if GRASS want's to stay relevant on OS X, a
>> solution needs to be found to compile and install it on a mac as easy
>> as it was before (homebrew, which I relly like, and also the frameworks
>> From  William Kyngesburye and michael Barton?)
>> I mean - I have found a way of compiling GRASS 7.1 (see my post from the
>> 07 January in the topic "SUCCESS (running): Compiling grass 7 svn trunk
>> on OS X El Capitan") which gives me a working GRASS GIS including GUI,
>> but this is not really a solution.
>> I asked for help but did not get any response (subject "grass 7 svn
>> trunk on OS X El Capitan - need help").
>> So I would like to know if somebody would be prepared to help or at
>> least tell me if I am following the wrong track. I am not very
>> experienced in compiling / linking / make files but I have a basic
>> understanding.
>> I simply refuse to accept that GRASS will die for OSX users (>= El
>> Capitan).
>> Cheers,
>> Rainer
>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
>> Centre of Excellence for Invasion Biology
>> Stellenbosch University
>> South Africa
>> Tel :       +33 - (0)9 53 10 27 44
>> Cell:       +33 - (0)6 85 62 59 98
>> Fax :       +33 - (0)9 58 10 27 44
>> Fax (D):    +49 - (0)3 21 21 25 22 44
>> email:      Rainer at krugs.de
>> Skype:      RMkrug
>> PGP: 0x0F52F982
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
> Second Pogril: I don't know.  Why IS life like sticking your head in a bucket filled with hyena offal?
> First Pogril: I don't know either.  Wretched, isn't it?
> -HitchHiker's Guide to the Galaxy
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160121/0064079e/attachment.sig>
