[GRASS-dev] GRASS on OS X El Capitan - slowly dying or is something happening?
William Kyngesburye woklist at kyngchaos.com
Wed Jan 20 15:46:43 PST 2016
There are a couple ideas floating around.
I'm surprised Homebrew has a problem.  Since it would leave everything in the configured location (/usr/local), there should not be library paths pointing somewhere else that would need DYLD_LIBRARY_PATH to divert.
> On Jan 20, 2016, at 8:37 AM, Rainer M Krug <Rainer at krugs.de> wrote:
> Hi
> Sorry for this blunt subject - but I am wondering if anybody is looking
> at supporting El Capitan without having to disable SIP (System Integrity
> Protection). SIP is likely to stay, and for many (including myself)
> disabling SIP is not really an option as it goes to deep into the OS.
> So my personal opinion: if GRASS want's to stay relevant on OS X, a
> solution needs to be found to compile and install it on a mac as easy
> as it was before (homebrew, which I relly like, and also the frameworks
> From  William Kyngesburye and michael Barton?)
> I mean - I have found a way of compiling GRASS 7.1 (see my post from the
> 07 January in the topic "SUCCESS (running): Compiling grass 7 svn trunk
> on OS X El Capitan") which gives me a working GRASS GIS including GUI,
> but this is not really a solution.
> I asked for help but did not get any response (subject "grass 7 svn
> trunk on OS X El Capitan - need help").
> So I would like to know if somebody would be prepared to help or at
> least tell me if I am following the wrong track. I am not very
> experienced in compiling / linking / make files but I have a basic
> understanding.
> I simply refuse to accept that GRASS will die for OSX users (>= El
> Capitan).
> Cheers,
> Rainer
> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
> Centre of Excellence for Invasion Biology
> Stellenbosch University
> South Africa
> Tel :       +33 - (0)9 53 10 27 44
> Cell:       +33 - (0)6 85 62 59 98
> Fax :       +33 - (0)9 58 10 27 44
> Fax (D):    +49 - (0)3 21 21 25 22 44
> email:      Rainer at krugs.de
> Skype:      RMkrug
> PGP: 0x0F52F982
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know.  Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either.  Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
