[GRASS-dev] [GRASS GIS] #2873: Simplify usage of GRASS in Python from outside
trac at osgeo.org
Sat Jan 23 14:58:21 PST 2016
Reporter: wenzeslaus | Owner: grass-dev@…
Type: | Status: new
enhancement |
Priority: major | Milestone: 7.1.0
Component: Python | Version: svn-trunk
Resolution: | Keywords: startup, installation, scripts,
| interpreter, windows installer, pygrass,
CPU: | temporal, bootstrap, boilerplate
Unspecified | Platform: All
Comment (by wenzeslaus):
Replying to [comment:1 hellik]:
> Replying to [ticket:2873 wenzeslaus]:
> > GRASS Python packages could go to the system packages directory, so
that we avoid the need for setting `PYTHONPATH`. This might work well on
MS Windows when usage of system Python is implemented as described in
#2333.
> there is no ''system Python'' in windows. users always has to install
python manually systemwide, possibly interfering with other python
installations installed by other software.
By system Python I mostly mean what #2333 is talking about. Possible
interference is the inherent issue of Windows operating system. I'm OK
with including multiple options in the installer giving the choice to the
user (with the last option being "Don't know what to choose? Install
Ubuntu and let the package managers solve it for you." ;-).
> > On MS Windows, putting more things on `PATH` is standard procedure
from what I have seen...
> > GRASS GIS executable should be on path on all platforms in the same
way as it is on path in Linux. This is maybe not standard on MS Windows
but at the end this is what users want (they want GRASS to be available
right away).
> IMHO it is not a good practice to put ''everything'' in ''%PATH%'' in
windows. ''poisoning'' %PATH% should be avoided IMHO.
I'm not sure if we can do it. Is there a another way how to set path to
dynamic libraries for a process (so that Python scripts using GRASS ctypes
work)?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2873#comment:2>
