[GRASS-dev] [GRASS GIS] #2878: "v.in.ogr -i" throws an error when importing a GeoJSON file containing a single point.
trac at osgeo.org
Wed Jan 27 08:35:40 PST 2016
single point.
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: Vector | Version: unspecified
Resolution: | Keywords: v.in.ogr v.import
CPU: Unspecified | Platform: Unspecified
Changes (by neteler):
* version: => unspecified
Comment:
Replying to [ticket:2878 pmav99]:
> I was trying to use `v.import` and I think I run into a bug. AFAIK the
error is caused by `v.in.ogr -i`.
> In this container I was using [67592] so this should be present in
`7.0.3`.
> These are the steps to reproduce it:
> 1. Create a file with the following contents and save it e.g. as
`~/input.json`:
I did that and simply tried with OGR:
ogrinfo -so ~/input.json
ERROR 1: GeoJSON parsing error: quoted object property name expected (at
offset 1)
ERROR 4: Failed to read GeoJSON data
offset 1)
FAILURE:
Unable to open datasource `/home/neteler/input.json' with the following
drivers.
-> PCIDSK
-> JP2OpenJPEG
-> JPEG2000
-> PDF
-> ESRI Shapefile
-> GeoJSON
-> Interlis 1
Are you sure that this is valid syntax? Since OGR cannot read it, also
v.in.ogr cannot.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2878#comment:1>
