[GRASS-dev] Upcoming 7.2.0: review which addons to move to core
Rainer M Krug
Rainer at krugs.de
Mon Jul 4 02:00:18 PDT 2016
Vaclav Petras <wenzeslaus at gmail.com> writes:
> On Sun, Jul 3, 2016 at 6:32 PM, Markus Neteler <neteler at osgeo.org> wrote:
> The general criteria are
> - code follows submission standards
> - must be portable
> - must be well documented with examples
> - must be of interest to a wider audience
> I would add "well tested (i.e. very mature) or having somebody willing to fix it (soon) if needed".
> Related to that, I wonder if we should create some standard mechanism for introducing experimental things - things which might later show as unstable,
> not useful or buggy. For example, I introduced v.decimate which is now in 7.2 branch. It has its merit but I started to think that perhaps a different set of
> functions or interface can be more useful there. I wonder if I should just put [experimental - use with care] at the end of the module description.
I would add the following:
1) add [experimental] / [beta] / ... behind the in the menu
2) disable the experimental / beta / ... addons
3) add an option to enable all the experimental / beta / ... addons, which can than state
"experimental, might make your computer explode, use at own risk and only in
well ventilated rooms"...
Cheers,
Rainer
> This is out-of-topic here, but similarly we might want to introduce something like [deprecated] for modules, options and flags.
> Vaclav
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160704/7c7077f3/attachment-0001.sig>
