[GRASS-dev] [GRASS GIS] #3091: The RUN_GISBASE variable is not set correctly on FreeBSD
trac at osgeo.org
Tue Jul 5 22:58:34 PDT 2016
Reporter: pieside | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Default | Version: 7.0.4
Resolution: | Keywords: FreeBSD
CPU: x86-64 | Platform: Other Unix
Comment (by glynn):
Replying to [ticket:3091 pieside]:
> The compilation search the includes files (e.g., gis.h) in this
directory.
The include flags are actually:
INC = -I$(ARCH_DISTDIR)/include -I$(GISBASE)/include
from Grass.make.
> But it is empty. All the includes are located in another directory:
dist.amd64
Headers are supposed to be installed in $(ARCH_INCDIR), which is set to
ARCH_INCDIR = $(ARCH_DISTDIR)/include/grass
Note that ARCH_DISTDIR is set thus:
ARCH_DISTDIR = $(GRASS_HOME)/dist.$(ARCH)
and both GRASS_HOME and ARCH appear to be set correctly in your attached
Platform.make file:
ARCH = amd64-portbld-freebsd11.0
GRASS_HOME = /usr/ports/databases/grass7/work/grass-7.0.4
> Why is the first directory empty?
Is it only headers that are in dist.amd64? Everything that will eventually
be installed should be within the dist.amd64-portbld-freebsd11.0 directory
except for the grass71 startup script, which should be in bin.amd64
-portbld-freebsd11.0. Knowing which files go where would provide some
clues as to the source of the problem.
I suggest that you examine the output from "make". If you didn't capture
it to a file, run "make clean" then re-build with e.g.
make >build.log 2>&1
Check for the "install" commands which install headers, e.g.
/usr/bin/install -c -m 644 gmath.h
/usr/ports/databases/grass7/work/grass-7.0.4/dist.amd64-portbld-
freebsd11.0/include/grass/gmath.h
If those look okay, there's something wrong with the install program (or
the install-sh script, if that's being used). Otherwise, the issue may be
with the build system.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3091#comment:1>
