[GRASS-dev] [GRASS GIS] #3091: The RUN_GISBASE variable is not set correctly on FreeBSD
trac at osgeo.org
Thu Jul 7 06:30:37 PDT 2016
Reporter: pieside | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Default | Version: 7.0.4
Resolution: | Keywords: FreeBSD
CPU: x86-64 | Platform: Other Unix
Comment (by pieside):
After some tests, I found that the issue is probably coming from the ports
tree framework which overrides the value of ARCH. This seems to comfort
that the issue may be with the build system.
To avoid duplicate and because it seems to be FreeBSD specific, I continue
the discussion here:
[https://forums.freebsd.org/threads/56766/#post-323073]
Ticket URL: <https://trac.osgeo.org/grass/ticket/3091#comment:2>
