[GRASS-dev] [GRASS GIS] #3089: exec_command fails if '.exe' not included in filename.
trac at osgeo.org
Thu Jul 14 04:25:31 PDT 2016
Reporter: artegion | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Default | Version: svn-releasebranch72
Resolution: | Keywords:
CPU: Unspecified | Platform: MSWindows 7
Comment (by martinl):
Replying to [comment:1 glynn]:
> In this specific case, I'd suggest just using run_command() instead of
exec_command(). On Windows, they amount to essentially the same thing
anyhow; Windows doesn't have a "real" execve(); it just executes the
command as a child process, waits for the child to terminate, then
exit()s.
done in all active branches (r68954, r68955, r68956). Testing welcome,
will be included in the next daily build (1) - so 14/7+.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3089#comment:2>
