[GRASS-dev] [GRASS GIS] #2558: wxgui: profile surface map, bivariate scatter plot, histogram of raster map broken with wxPython 3.0.2 but work fine fine with 2.8
trac at osgeo.org
Fri Jul 15 10:45:39 PDT 2016
Reporter: humu2015 | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 6.4.6
Component: wxGUI | Version: 7.0.4
Resolution: | Keywords: wxgui
CPU: All | Platform: All
Comment (by cmbarton):
One reason to keep available the possibility of using wxPython 3.0.2 (or
Phoenix when it is developed to a place where it is useable), is that 2.8
is 32 bit only on the Mac. Maybe on other platforms too.
However, most other parts of GRASS and its dependencies have migrated to
64 bit architecture. This is causing all kinds of difficulties in
compiling because it has to be done dual architecture (32/64 bit) and some
programs do not support this or don't support it well.
I'm trying to find out where the problems in wxPython 3 are so that they
can be fixed. The plot.py problem was the worst but is easily patched.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2558#comment:13>
