[GRASS-dev] Travis-ci and tests of grass 7
Markus Neteler neteler at osgeo.org
Thu Jun 2 09:13:13 PDT 2016
back to this topic:
On Thu, Sep 3, 2015 at 5:24 PM, Rainer M Krug <Rainer at krugs.de> wrote:
> Hi
> is anything happening in regards to the travis-ci integration? I did not
> get any feedback or how I can submit it to the svn.
> In regards to testing: I know about the python gunit tests [1]. Are
> there any other tests which should be included in the scripts? Should
> detailed results generated by the tests be uploaded somewhere in case of
> an error? Or always? If yes, where?
> Also, should the same tests be done for other versions?
> Cheers,
> Rainer
> Rainer M Krug <Rainer at krugs.de> writes:
>> Quick update: the tests are running, the forked github repo is
>> https://github.com/rkrug/grass-ci
>> and the travis-ci is here (the actually running one)
>> https://travis-ci.org/rkrug/grass-ci/builds/77509876
>> It looks good now.
I see the open pull request:
https://github.com/GRASS-GIS/grass-ci/pull/1
Anything to be done there? Was it integrated? Or stuck at
https://trac.osgeo.org/grass/ticket/2733
thanks,
Markus
