[GRASS-dev] Travis-ci and tests of grass 7
Rainer M Krug Rainer at krugs.de
Thu Jun 2 10:59:45 PDT 2016
Markus Neteler <neteler at osgeo.org> writes:
> Hi,
> back to this topic:
> On Thu, Sep 3, 2015 at 5:24 PM, Rainer M Krug <Rainer at krugs.de> wrote:
>> Hi
>> is anything happening in regards to the travis-ci integration? I did not
>> get any feedback or how I can submit it to the svn.
>> In regards to testing: I know about the python gunit tests [1]. Are
>> there any other tests which should be included in the scripts? Should
>> detailed results generated by the tests be uploaded somewhere in case of
>> an error? Or always? If yes, where?
>> Also, should the same tests be done for other versions?
>> Cheers,
>> Rainer
>> Rainer M Krug <Rainer at krugs.de> writes:
>>> Quick update: the tests are running, the forked github repo is
>>> https://github.com/rkrug/grass-ci
>>> and the travis-ci is here (the actually running one)
>>> https://travis-ci.org/rkrug/grass-ci/builds/77509876
>>> It looks good now.
> I see the open pull request:
> https://github.com/GRASS-GIS/grass-ci/pull/1
> Anything to be done there? Was it integrated? Or stuck at
> https://trac.osgeo.org/grass/ticket/2733
I think it was stuck - but I haven't looked at it since and I have no
idea if it still works. I think there were some changes on travis
concerning OS X?
If you are interested, I could look at it again.
Cheers,
Rainer
> thanks,
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160602/7a98d0bf/attachment.sig>
