[GRASS-dev] GSoC 2016 - PyQt GRASS - Report 2
Ondřej Pešek
pesej.ondrek at gmail.com
Sat Jun 4 02:27:47 PDT 2016
Hi all!
Here is the second report of my GSoC project - PyQt based GUI of GRASS
automatically generated from XML
What did you get done this week?
* Now the code is reading those types - float, range, sql_query, flags
* It also writes their names or labels and types into GUI
What do you plan on doing next week?
* Other types - especially I have on my mind string and name
* I also want to make the GUI little bit more elegant. It means I want to
insert spacer on the end of every tab -> it means that widgets will be at
the top, not averagely placed.
Are you blocked on anything?
* Not yet
Here is the wiki with screenshots etc.:
https://trac.osgeo.org/grass/wiki/GSoC/2016/PyQtGUI
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160604/a5dd40f2/attachment.html>
