[GRASS-dev] Travis-ci and tests of grass 7
Rainer M Krug Rainer at krugs.de
Tue Jun 7 23:50:43 PDT 2016
Just to make sure that this doesn't get lost again.
Rainer
Rainer M Krug <Rainer at krugs.de> writes:
> Markus Neteler <neteler at osgeo.org> writes:
>>>> Anything to be done there? Was it integrated? Or stuck at
>>>> https://trac.osgeo.org/grass/ticket/2733
>>> I think it was stuck - but I haven't looked at it since and I have no
>>> idea if it still works. I think there were some changes on travis
>>> concerning OS X?
>>> If you are interested, I could look at it again.
>> Interested yes, but I cannot help with the Travis CI things.
>> Just don't like efforts potentially lost :)
> That's why I didn't continue looking into this - no response.
> OK. I checked the travis testing, updated the OS X config options to use the
> same as Linux, usage of gdal 1... as gdal 2.0 is not compiling at the
> moment in OS X, and the tests passed.
> Pull request is at:
> https://github.com/GRASS-GIS/grass-ci/pull/1
> travis tests at
> https://travis-ci.org/rkrug/grass-ci
> Who is actually maintaining the travis integration?
> One question: what is the relationship between the grass-ci on github
> and the svn repo? Are they kept in sync?
> Rainer
>> Markus
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160608/bd85fe21/attachment.sig>
