[GRASS-dev] hacking configure for gettext
Michael Barton
Michael.Barton at asu.edu
Wed Jun 8 12:50:36 PDT 2016
Thanks Glynn.
I'll try this out and see what happens. I've also tried to point the generic --with-includes= and
--with-libs= switches to my gettext location but it has made no difference.
It looks like it is bundled dependencies that cause Mac OSX SIP to block GRASS launching. Trying to run the install_tool on every possible binary file that might link with one of these seems unrealistic. The simplest solution seems to be to build all dependencies outside of the Mac system folders. That is a pain but doable...if GRASS will recognize these dependencies in their non-system locations.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice: 480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Jun 8, 2016, at 12:41 PM, Glynn Clements <glynn at gclements.plus.com> wrote:
> Michael Barton wrote:
>> I would like GRASS to use gettext that is installed in a location
>> NOT in the standard /usr/local... I have no problem building gettext
>> in such a location but I am having problems telling GRASS where to
>> find it.
>> The configure switch to enable gettext is --with-nls. I've tried
>> adding additional arguments
>> --with-nls-includes="/Users/cmbarton/grass_source/gettext/gettext_dist/include"
>> --with-nls-libs="/Users/cmbarton/grass_source/gettext/gettext_dist/lib"
>> to tell GRASS where to find gettext but these do not seem to do the
>> trick.
>> Can someone familiar with the build system suggest how to specify
>> where to find gettext or now to modify configure so that GRASS can
>> find gettext in this other location?
> Currently, gettext is treated as a system function, i.e. there's no
> way to configure search paths beyond the generic --with-includes= and
> --with-libs= switches. It's checked initially without additional
> libraries (AC_CHECK_FUNC), and if that fails with -lintl
> (AC_CHECK_LIB).
> To treat it as an external library function, try the attached patch.
> Note that you'll need to add $(INTLINC) to ... something. probably
> Either INC (in Grass.make) or NLS_CFLAGS (in Compile.make). Adding it
> to individual Makefiles isn't feasible because <libintl.h> is included
> from <grass/glocale.h>, which is included by practically everything.
> Index: configure.in
> --- configure.in (revision 68639)
> +++ configure.in (working copy)
> @@ -321,6 +321,9 @@
> LOC_ARG_WITH_INC(readline, Readline)
> LOC_ARG_WITH_LIB(readline, Readline)
> +LOC_ARG_WITH_INC(nls, NLS)
> +LOC_ARG_WITH_LIB(nls, NLS)
> LOC_ARG_WITH_INC(tiff, TIFF)
> LOC_ARG_WITH_LIB(tiff, TIFF)
> @@ -1652,20 +1655,28 @@
> LOC_CHECK_USE(nls,NLS,USE_NLS)
> +if test -n "${USE_NLS}" ; then
> + AC_DEFINE(USE_NLS)
> +INTLINC=
> +LOC_CHECK_INC_PATH(nls,NLS,INTLINC)
> +LOC_CHECK_INCLUDES(libintl.h,NSL,$INTLINC)
> INTLLIB=
> HAVE_NLS=
> -if test -n "${USE_NLS}" ; then
> - AC_DEFINE(USE_NLS)
> +LOC_CHECK_LIB_PATH(nsl,NLS,INTLLIB)
> -AC_CHECK_FUNC(gettext, INTLLIB=, [
> -AC_CHECK_LIB(intl, gettext, INTLLIB=-lintl, [
> - AC_MSG_ERROR([*** Unable to locate gettext() function.])
> +LOC_CHECK_FUNC(gettext,NLS,INTLLIB,,,,,[
> +LOC_CHECK_LIBS(intl,gettext,NLS,$INTLLIB,INTLLIB,,,)
> HAVE_NLS=1
> fi
> +AC_SUBST(INTLINC)
> AC_SUBST(INTLLIB)
> AC_SUBST(HAVE_NLS)
