[GRASS-dev] Travis-ci and tests of grass 7
    Rainer M Krug
    Rainer at krugs.de
    Thu Jun  9 01:54:16 PDT 2016
Markus Neteler <neteler at osgeo.org> writes:
>>> On Thu, Jun 2, 2016 at 7:59 PM, Rainer M Krug <Rainer at krugs.de> wrote:
>>>>> Anything to be done there? Was it integrated? Or stuck at
>>>>> https://trac.osgeo.org/grass/ticket/2733
>>>> I think it was stuck - but I haven't looked at it since and I have no
>>>> idea if it still works. I think there were some changes on travis
>>>> concerning OS X?
>>>> If you are interested, I could look at it again.
>>> Interested yes, but I cannot help with the Travis CI things.
>>> Just don't like efforts potentially lost :)
>> That's why I didn't continue looking into this - no response.
>> OK. I checked the travis testing, updated the OS X config options to use the
>> same as Linux, usage of gdal 1... as gdal 2.0 is not compiling at the
>> moment in OS X, and the tests passed.
>> Pull request is at:
>> https://github.com/GRASS-GIS/grass-ci/pull/1
>> travis tests at
>> https://travis-ci.org/rkrug/grass-ci
> While I don't know if we have a bidirectional SVN <--> git(hub)
> integration, I have committed it now in SVN trunk as r68652.
Thanks for committing.
>> Who is actually maintaining the travis integration?
> No idea - AFAIK Ivan, Martin, Vaclav were involved.
Thanks.
>> One question: what is the relationship between the grass-ci on github
>> and the svn repo? Are they kept in sync?
> I have no clue! I'll bring that up in a separate thread.
Thanks - would be good to know.
Cheers,
Rainer
> Markus
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160609/fc3371ea/attachment.sig>
