[GRASS-dev] Travis-ci and tests of grass 7
Rainer M Krug
Rainer at krugs.de
Thu Jun 9 02:14:00 PDT 2016
Rainer M Krug <Rainer at krugs.de> writes:
> Markus Neteler <neteler at osgeo.org> writes:
>>>> On Thu, Jun 2, 2016 at 7:59 PM, Rainer M Krug <Rainer at krugs.de> wrote:
>>>>>> Anything to be done there? Was it integrated? Or stuck at
>>>>>> https://trac.osgeo.org/grass/ticket/2733
>>>>> I think it was stuck - but I haven't looked at it since and I have no
>>>>> idea if it still works. I think there were some changes on travis
>>>>> concerning OS X?
>>>>> If you are interested, I could look at it again.
>>>> Interested yes, but I cannot help with the Travis CI things.
>>>> Just don't like efforts potentially lost :)
>>> That's why I didn't continue looking into this - no response.
>>> OK. I checked the travis testing, updated the OS X config options to use the
>>> same as Linux, usage of gdal 1... as gdal 2.0 is not compiling at the
>>> moment in OS X, and the tests passed.
>>> Pull request is at:
>>> https://github.com/GRASS-GIS/grass-ci/pull/1
>>> travis tests at
>>> https://travis-ci.org/rkrug/grass-ci
>> While I don't know if we have a bidirectional SVN <--> git(hub)
>> integration, I have committed it now in SVN trunk as r68652.
> Thanks for committing.
Just realized the on-failure notification=s are still disabled - please
see my pull request where I enabled them again.
https://github.com/GRASS-GIS/grass-ci/pull/2
Cheers,
Rainer
>>> Who is actually maintaining the travis integration?
>> No idea - AFAIK Ivan, Martin, Vaclav were involved.
> Thanks.
>>> One question: what is the relationship between the grass-ci on github
>>> and the svn repo? Are they kept in sync?
>> I have no clue! I'll bring that up in a separate thread.
> Thanks - would be good to know.
> Cheers,
> Rainer
>> Markus
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
Rainer M. Krug
email: Rainer<at>krugs<dot>de
PGP: 0x0F52F982
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160609/91077d7f/attachment.sig>
