[GRASS-dev] [GRASS GIS] #3059: r.external.out does not write CRS information
trac at osgeo.org
Fri Jun 10 02:23:00 PDT 2016
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Default | Version: 7.0.4
Resolution: | Keywords: r.external.out
CPU: Unspecified | Platform: Unspecified
Comment (by sbl):
Some additional observations:
A colleague and me are facing significant "interoperability problems" with
GeoTiffs produced with r.external.out, which (after FTP transfer) could
not be opened in ENVI.
ENVI complains about broken corner coordinates and a corrupted LZW-table.
The files are solar radiation grids (all integer) and are saved as Int32
by r.external.out.
They were results from a tiled processing which was merged using r.patch.
When I export via r.out.gdal I get a warning message that Metadata exceeds
32000 bytes and cannot be written to GeoTiff, and therefore will be
transferred to PAM. So this is possibly related to #3056
Ticket URL: <https://trac.osgeo.org/grass/ticket/3059#comment:1>
