[GRASS-dev] [GRASS GIS] #3059: r.external.out does not write CRS information
trac at osgeo.org
Fri Jun 10 08:25:35 PDT 2016
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.0.5
Component: Raster | Version: 7.0.4
Resolution: | Keywords: r.external.out
CPU: Unspecified | Platform: Unspecified
Changes (by neteler):
* priority: normal => major
* component: Default => Raster
Comment:
I can reproduce it with the NC location:
# NC Location
g.region raster=elevation -p
g.proj -w
PROJCS["Lambert Conformal Conic",
GEOGCS["grs80",
DATUM["North_American_Datum_1983",
SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Lambert_Conformal_Conic_2SP"],
PARAMETER["standard_parallel_1",36.16666666666666],
PARAMETER["standard_parallel_2",34.33333333333334],
PARAMETER["latitude_of_origin",33.75],
PARAMETER["central_meridian",-79],
PARAMETER["false_easting",609601.22],
PARAMETER["false_northing",0],
UNIT["Meter",1]]
mkdir -p $HOME/tmp
r.external.out directory=$HOME/tmp extension=.tif format=GTiff
options="COMPRESS=LZW,PREDICTOR=2"
r.mapcalc expression="test = 1"
gdalinfo $HOME/tmp/test.tif
Driver: GTiff/GeoTIFF
Files: test.tif
Size is 1500, 1350
Coordinate System is `'
Origin = (630000.000000000000000,228500.000000000000000)
Pixel Size = (10.000000000000000,-10.000000000000000)
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=BAND
Corner Coordinates:
Apparently some GDAL part is not initialized completely. I see in
https://trac.osgeo.org/grass/browser/grass/trunk/lib/raster/gdal.c#L431
that the use of GPJ_grass_to_wkt() is commented. Maybe that part needs to
be updated/completed?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3059#comment:2>
