[GRASS-dev] [GRASS GIS] #3059: r.external.out does not write CRS information
GRASS GIS trac at osgeo.org
Mon Jun 13 13:24:19 PDT 2016
  Reporter:  sbl          |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  major        |  Milestone:  7.0.5
 Component:  Raster       |    Version:  7.0.4
Resolution:               |   Keywords:  r.external.out
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by glynn):
 Replying to [comment:2 neteler]:
 > Apparently some GDAL part is not initialized completely. I see in
 > https://trac.osgeo.org/grass/browser/grass/trunk/lib/raster/gdal.c#L431
 > that the use of GPJ_grass_to_wkt() is commented. Maybe that part needs
 to be updated/completed?
 The main problem is that gproj depends upon libgis, which means that
 libgis cannot depend upon gproj. However, it may be possible to load gproj
 dynamically, in the same manner as GDAL. The only other option is to merge
 gproj into libgis, making GDAL (along with its large and open-ended set of
 dependencies) a hard dependency of libgis.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3059#comment:3>
