[GRASS-dev] [GRASS GIS] #3059: r.external.out does not write CRS information
GRASS GIS trac at osgeo.org
Wed Jun 15 12:13:20 PDT 2016
  Reporter:  sbl          |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  major        |  Milestone:  7.0.5
 Component:  Raster       |    Version:  7.0.4
Resolution:               |   Keywords:  r.external.out
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by neteler):
 Replying to [comment:3 glynn]:
 > Replying to [comment:2 neteler]:
 > > Apparently some GDAL part is not initialized completely. I see in
 https://trac.osgeo.org/grass/browser/grass/trunk/lib/raster/gdal.c#L431
 > > that the use of GPJ_grass_to_wkt() is commented. Maybe that part needs
 to be updated/completed?
 > The main problem is that gproj depends upon libgis, which means that
 libgis cannot depend upon gproj. However, it may be possible to load gproj
 dynamically, in the same manner as GDAL.
 Rather than merging libproj into libgis, your suggestion of dynamical
 loading of libproj sounds more viable to avoid a dependency "hell".
Ticket URL: <https://trac.osgeo.org/grass/ticket/3059#comment:4>
