[GRASS-dev] GRASS 7.3 64bit SIP Enabled GRASS Error
Michael Barton Michael.Barton at asu.edu
Fri Jun 10 11:07:21 PDT 2016
This is very frustrating if it is repeated for others.
The test version works fine with SIP disabled on El Capitan. But with it enabled, it gives the error below. It should have no links that touch system folders. And the error does not reference any file in a system folder. It is looking for a file on a path that references my machine that it was compiled on. But this is not a problem with SIP disabled. I could run install_tool on _core_.so of course. But I worry that this is not the only file with a problem, only the first one that stops the program.
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
Begin forwarded message:
From: Sean Bergin <sbergin at asu.edu<mailto:sbergin at asu.edu>>
Subject: SIP Enabled GRASS Error
Date: June 10, 2016 at 10:53:04 AM MST
To: Michael Barton <Michael.Barton at asu.edu<mailto:Michael.Barton at asu.edu>>
Reply-To: <Sean.Bergin at asu.edu<mailto:Sean.Bergin at asu.edu>>
mac:~ sbergin$ '/Applications/GRASS-7.3.app/Contents/MacOS/grass.sh'; exit
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
Python 2.7.10 found.
Cleaning up temporary files...
Starting GRASS GIS...
  File "/Applications/GRASS-7.3.app/Contents/MacOS/gui/wxpython/gis_set.py", line 31, in <module>
    from core import globalvar
  File "/Applications/GRASS-7.3.app/Contents/MacOS/gui/wxpython/core/globalvar.py", line 96, in <module>
    import wx
  File "/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/__init__.py", line 45, in <module>
    from wx._core import *
  File "/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_core.py", line 4, in <module>
    import _core_
ImportError: dlopen(/Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_core_.so, 2): Library not loaded: /Users/cmbarton/grass_source/wxp3/usr/local/lib/libwx_osx_cocoau-3.0.0.2.0.dylib
  Referenced from: /Applications/GRASS-7.3.app/Contents/MacOS/etc/python/wx/_core_.so
  Reason: image not found
ERROR: Error in GUI startup. See messages above (if any) and if necessary, please report this error to the GRASS developers.
On systems with package manager, make sure you have the right GUI package, probably named grass-gui, installed.
To run GRASS GIS in text mode use the -text flag.
Exiting...
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
Deleting expired sessions...10 completed.
[Process completed]
Sean Bergin
Ph.D. Candidate, Archaeology
Graduate Assistant
CoMSES & Mediterranean Landscape Dynamics Projects
School of Human Evolution and Social Change
Tempe, AZ 85287-2402
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20160610/487c4e2f/attachment-0001.html>
