[GRASS-dev] [GRASS GIS] #3063: In grass 7.3, no shared object files libgrass_vector and libgrass_raster 7.1
GRASS GIS trac at osgeo.org
Mon Jun 13 09:10:13 PDT 2016
7.1
  Reporter:  pvanbosgeo   |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.3.0
 Component:  Default      |    Version:  unspecified
Resolution:               |   Keywords:
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by neteler):
 Replying to [comment:3 pvanbosgeo]:
 > I must be missing something obvious here,
 BTW: please add which operating system you are using.
 > but this is what I do:
 > Remove my previous install
 ok, but we shure that the files are really gone.
 > Completely new checkout
 No need to do that.
 make distclean
 is enough. To be double, sure run also next to find remaining garbage:
 svn status --no-ignore
 > Compile and run
 ok, now, within the session, run
 which g.region
 ldd `which g.region | grep grass`
 in order to see where g.region is and which libraries it loads from where.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3063#comment:4>
