[GRASS-dev] [GRASS GIS] #2045: r.to.vect: use less memory
trac at osgeo.org
Wed Jun 22 14:45:47 PDT 2016
Reporter: mlennert | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.5
Component: Raster | Version: svn-trunk
Resolution: | Keywords: r.to.vect
CPU: Unspecified | Platform: Unspecified
Comment (by mlennert):
Replying to [comment:18 mmetz]:
> Replying to [comment:16 mlennert]:
> > > export GRASS_VECTOR_LOWMEM=1
> > > time v.build seg_full
> > Construction de la topologie pour la carte vectorielle
> > <seg_full at rtovecttest>...
> > Enregistrement des primitives ...
> > 63282475 primitives registered
> > 397657832 vertices registered
> > Construction des surfaces ...
> > Processus arrêté
> > real 84m57.309s
> > user 19m8.872s
> > sys 54m37.868s
> Strange. Topology building should be much slower with
GRASS_VECTOR_LOWMEM, therefore I would expect v.build with
GRASS_VECTOR_LOWMEM to fail later, not earlier. Can you provide data and
commands for testing?
Data and info provided via private mail.
Previous posters have also reported that setting GRASS_VECTOR_LOWMEM
didn't make much of a difference, so maybe the problem is there ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2045#comment:19>
