[GRASS-dev] problem in detecting the projection information from the raster layers when using the batch import
Paulo van Breugel p.vanbreugel at gmail.com
Sun Jun 26 02:16:07 PDT 2016
On 26-06-16 01:25, Markus Neteler wrote:
> On Fri, Jun 24, 2016 at 2:26 PM, Paulo van Breugel
> <p.vanbreugel at gmail.com> wrote:
>> I want to import raster layers from
>> https://www.york.ac.uk/environment/research/kite/resources/ (latlon/WGS84)
>> into a location/mapset (also latlon/WGS84). This is no problem when
>> importing one by one (Source type = File), but when I try to import all
>> raster layers in a directory (Source type = Directory), I am getting the
>> message that "Projection of following layers do not match with projection of
>> current location" (listing all layersin the directory). So there seems to be
>> a problem in detecting the projection information from the raster layers
>> when using the batch import.
> Do all of them come with the *identical* projection string?
Yes, I think so, they are all latlon (wgs84) layers. From gdalinfo:
Size is 2049, 2123
Coordinate System is:
GEOGCS["WGS 84",
     DATUM["WGS_1984",
         SPHEROID["WGS 84",6378137,298.257223563,
             AUTHORITY["EPSG","7030"]],
         AUTHORITY["EPSG","6326"]],
     PRIMEM["Greenwich",0],
     UNIT["degree",0.0174532925199433],
     AUTHORITY["EPSG","4326"]]
Origin = (-24.859999999999999,42.460000000000001)
Pixel Size = (0.041659346022450,-0.041658031088083)
> Markus
